Synchronizing the two Host FIFO with two FPGA FIFO for modulation propose
Hello everyone,
I've written code to make pulses and used them to modulate a sine wave using a sine waveform generator. I generate the pulses in a Single Cycle Time Loop and do the modulation with the sine wave in a simple While loop. I'm using myRIO FPGA, and its analog output can't be used in the Single Cycle Time Loop, so I use it in the While loop. Both FPGA FIFOs are used in the Single Cycle Time Loop. However, when I read back the data on the host, I find that the pulse and modulated sine wave aren't in phase with each other; there's some delay.
If anyone has experience with this issue, I'd appreciate your assistance. Please check out the screenshot of the modulated sine and pulse waveforms below.
Thanks and regards.
(547 Views)
(543 Views)
The absence of code means an absence of pointers to what is wrong.....
(522 Views)
