Synchronizing multiple modules cRIO-9063
Is there any point in synchronizing (master-slave) several modules that are on the same I/O node ?
Thanks for your advice !
(1,185 Views)
in each module you can make data acquistion rate to be synchronized with scan engine with specifiec rate not less than 10 hz .. is that what you need?
CLA
(1,172 Views)
No, I'm talking about sharing the master time Source, "Export Onboard Clock" in module Configuration.
(1,156 Views)
