Synchronizing displacement sensor and camera
i need some help regarding implementing a synchronizing diagram(producer ,consumer ) ...i couldnt delete some of the blocks(eg:transform block,etc.) in labview and some errors which i couldn't find whats wrong if anyone can help just reply i will connect
(194 Views)
You don't provide sufficient information to diagnose.
  • What are the error messages you get?
  • What is a "transform block"?
  • What is a "synchronizing diagram"?
  • Can you attach your VI?
(182 Views)
here im unable to delete the block but just the connections are able to delete
(173 Views)
I said "attach your VI". Showing a truncated code picture is not helpful.
How exactly are you trying to delete and what happens when you try?
(131 Views)
(86 Views)
What kind of camera are you using? Some industrial camera support triggering that can be used for synchronization.
https://tmesystems.net/
(54 Views)
