Synchronizing and polling Boolean TTL pulses in separate FPGA VIs
Hi guys, wondering if anyone can help me with a timing/synchronization problem.
In a nutshell, I have two FPGA cards, which I write to from a top level VI. I create a TTL pulse on one FPGA and I need the other FPGA VI to be able trigger off this. Right now I am polling a Boolean.
Specifically:
FPGA card 1 has two parallel loops: the control loop, and the pulse loop. In the pulse loop, I create digital pulses (TTLs) on the order of 500us period with a 40% duty cycle.
In the control loop, I am running a PID controller, but that`s irrelevant to my query. What is relevant is that depending on the TTL being On or Off, my PID will behave in a certain way. Now in the control loop, I access a local variable of the Pulse on/off Boolean coming from the Pulse loop. I have this wired up to output another TTL pulse in the control loop, to test if it`s working. It is, and I can compare pulses on an external oscilloscope. There`s maybe a 1us delay, which I can live with, and the two TTLs from the VI are in sync.
My problem is, how can I efficiently mimic the behavior in a separate control loop, in a separate VI running on a separate FPGA card?
For now, the VI on FPGA card 2 simply has a control loop that is polling a Boolean in order to trigger some different cases in a case structure.
I have tried using a FIFO write on FPGA card1 Pulse loop, but cannot work out how to read this efficiently in my control loop on FPGA card 2.
What I have tried is to Invoke the Method on a top level VI of the FPGA card 1 FIFO, invoke this as read, then pass the data to a second FIFO that is fed in the reference from FPGA card 2. This is in the Write method. And in the VI on FPGA card 2, I create a FIFO that reads in and outputs a Boolean.
My problem is that whenever I run the top level VI, only one FPGA VI will run at a time (I`m monitoring the respective loop counts). Interestingly, each time I click Run, the other FPGA card vi will run, and they alternate (one loop counter will run, while the other will be at 0, so not even starting).
I have two questions for anyone who was kind enough to follow my long explanation above:
1) Is there a better way to pass a Boolean which is being polled on a separate FPGA vi?
2) If the FIFO method is the way to go, have I done something silly?
I might not have given you enough information, so please ask if I have omitted something important.
Some details: I can accept up to around a 5us delay between the pulse ON/OFF stages that reaches the second FPGA VI.
I tried using a Read/Write Control in the top level to poll the Pulse On/OFF Boolean, but this took around 800us so was not useful for what I want to do.
I have attached screen shots of a stripped down version of my code, if that helps.
Thanks!
(2,809 Views)
Which type of FPGA card are you using? If it's PXI, then you can use the backplane trigger line(s) to synchronize your FPGA cards. There's a good example under "R Series", "Device Specific", "RIO Master-Slave".
(2,798 Views)
G'day BillMe,
Thanks for the reply, I'm using two PXI-7853Rs. I'll check the example that you suggested, much appreciated!
Seiji
(2,795 Views)
