Synchronize Serial Communication and DAQ
That is a snippet. Use the new pic viewer and you can drag-n-drop it too your desktop then to a block diagram.
Kudos for a Jing link with the new viewer.
"Should be" isn't "Is" -Jay
Message 11 of 13
(1,523 Views)
Jeff
I took your advice.
I played around with random generator, it is working fine. However I am facing problems when I use a waveform generator and producer consumer architecture. I am still loosing the serial data when I queue it to the consumer loop. The serial producer loop gets data every 10ms, and it puts in the queue, apparently when I am plotting it in the consumer loop. I am loosing the information. Two radings between every other reading is reading zero.
Is there a reason, you would like me to use notifiers rather than producer consumer architecture? My belief was that they should be able to do the same job.
Message 12 of 13
(1,521 Views)
I used the notifier for the slower aquisition because you can use get notifier status to expand the data to the queued data rate.   A queue does not work as a "latest element memory object" like a notifier can.
Subtle, but useful difference in a case like this.
Message 13 of 13
(1,505 Views)
