Sync a DMM DAQ to a Scope
I'm trying to sync a DMM (PIXe-4080) to a scope (PXIe-5172).
I noticed this post:
https://forums.ni.com/t5/High-Speed-Digitizers/Export-the-trigger-for-Scope-to-DMM/m-p/2646019
Is there a better solution after 11 years?
George Zou
(505 Views)
Please provide some more information on the task you want to realize.
Samplerates , pretrigger points , single shot or continous , ... other cards you have available (timer/counter/...)
Greetings from Germany
Henrik
LV since v3.1
(469 Views)
Thanks for reply.
This setup is not for one test.  so the sample rate, pre-trigger points will vary.  It's a finite sample single shot measurement.
There are a few NI DAQ cards available: analog input/output (PXIe-43XX), digital input/output(PXIe-65XX), ...
The setup is for measuring the time difference between signal change on the DMM and the one on the Scope.
There is another problem: the waveform from the DMM has no t0.
George Zou
(426 Views)
