Switchy Switchy Switchy
I have a PXI-6070E DAQ card, and a 2503 switching card that I've set up to
behave
like a 6x4 matrix. I'm trying to arrange things, so that in my LabView
code
I can use Acquire N analog scans with Hardware Trigger to gather my data.
I want to begin acquiring (actually, waiting for trigger voltage) and then
have my
code throw the requisite switches, thereby providing the trigger needed to
start acquisition.
The problem I have is this: The Acquire vi runs first, and the switching
vi will not
run until the Acquire vi has finished. I tried putting them in sequence,
but since
Acquire With Hardware Trig consists of a few other vis, the entire thing
must
finish before the Switch vi will run. I would really rather not embed the
Switch
vi
INTO the acquisition vi. I know this is a basic question, but I can't think
of many solutions.
How can I start the Acquire vi waiting for acquisition and then trigger the
switch?
(2,791 Views)
The solution is simple. The problem is that you are trying to read the
acquisition data before starting your switching, meaning the AI Read VI
in the Acquire N Scans with Analog Hardware Trigger VI. Therefore your
program is waiting until the acquisition buffer is full before it will
read all the data (that is the default of the AI Read VI). If you set
up the acquisition with the hardware trigger, start it, then do your
switching, then perform the AI Read VI, you can avoid this problem.
Mark
In article <397c8a4f@newsgroups.ni.com>,
up to
> behave
LabView
> code
> I ca
data.
then
> have my
needed to
> start acquisition.
switching
> vi will not
sequence,
> but since
thing
> must
embed the
> Switch vi
can't think
> of many solutions.
trigger the
> switch?
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,791 Views)
