Switching between 2 sets of values controlling the y axis on an xy graph.
Morning all,
I am very new to this (like 2 days now) and will soon be sitting the Labview core 1 and measurement fundamentals, so bare with me!!
Basically I am extracting 2 values from a string that is outputted from a board I have through IP, one value is for mains voltage and the second measurement is for battery voltage.
I would like the option to use a control switch to differentiate between what is being inputted the the graph at the push of a button.
Is there a way of doing this?
Thanks a lot
Alex                     Robot Happy
(3,092 Views)
Yeah its possible (though I dint understand your problem statement completely, I'm confident it is possible)...!!
--> you can even plot both (MAINS and BATTERY voltage) in the same graph...
well do you want to use a control (say a toggle switch) to control what voltage to display (either MAINS or BATTERY)... is it??
can u attach few of the samples reading here or what ever u coded so far...??
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,074 Views)
Hi thanks for the quick response,
as i said this is my first go with labview and less than a week trying so please bare with me on the vi as i am probably doing things the long winded way.
but basically i am reading from a string and taking the voltage when a system is running on mains power and also from a different section when the system is running on battery power. I would like the graph to have 2 possible inputs which as you said can be toggled either or.
i have attached my vi
Thanks alot!!
Alex
(3,054 Views)
Accepted by topic author Detox92
Did you try Select function ?
(3,043 Views)
Spot on thanks!
Simple as that!
(3,036 Views)
