Switching a boolean between two states
Hello
I'm new to Labview and i have a question regarding how to make a
boolean control to switch between true and false automatically.
For example, when i run the vi i want the control to be true for
1 sec. then false for 1 sec. and so on. ?
thanks
Noor
(3,064 Views)
jus a clue
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,064 Views)
Noor,
I'm new to LabVIEW too, but here is the way I would think to do it (though,
it may not be the best)
Create a while loop.
Inside the while loop, create a sequence.
Let the first frame be to wire a true constant (in functions -> boolean) to
your control
let the second frame be a wait timer set to 100ms
let the third frame be to wire a false constant to your control
let the fourth frame be another wait timer set to 100ms
I doubt this is the best way, but it is what came to mind.
Jon
"Kim" wrote in message
news:a414f800.0304270751.7f7345e3@posting.google.com...
> Hello
> For
> thanks
> Noor
(3,064 Views)
That's close, except the sequence is unnecessary. All you have to do is carry the boolean value in a shift registers and invert it with every iteration.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,064 Views)
