Switch digital outs at a certain time on and off
I want to switch 2 Digital-Outs at a certain time on and off and at the same time I have to read 4 Analog-INs with an very high scan rate (1000 - 200000 scan per sec). I tried the example "Count time-easy (DAQ-STC).vi" and modified it a little bit for my work.
The example alone worked very well but not in my real VI.
The problem is that in my VI the time count not work and so the digital outs won't be switched.
You can see it a part of my VI in the attachment.
thanks for your helpSmiley Very Happy
I use WinXP, LabView 6.1 with DAQcard-AI-16E-4
Message 1 of 8
(3,331 Views)
what about to place the 2nd threat in a while loop, too
Message 2 of 8
(3,301 Views)
I think you mean the threat under the while-loop.
I tried to place the 2nd threat in the same loop (time count) but it did not work.
Message 3 of 8
(3,295 Views)
i mean 2 parallel while loops
Message 4 of 8
(3,290 Views)
OK. I will try this at Monday. thanksSmiley Wink
Message 5 of 8
(3,285 Views)
I tried to place the 2nd threat in a parallel while-loop but this also didn't work.
The VI stops at the right time but the time count is not refreshed!!!
Message 6 of 8
(3,275 Views)
can you publish your current VI?
Message 7 of 8
(3,271 Views)
here it is, my VI with the 2 parallel while-loops.
Message 8 of 8
(3,262 Views)
