Sweep with Agilent function generator - rising amplitude
i am using an Agilent 33210A function generator and i try to generate a simple sinus sweep with constant amplitude.
For some reason the amplitude is increasing for the whole sweep-time. I basically used the Sweep VI from the Agilent 33xxx example VIs.
I only added the VOLT command to control the amplitude as described in the User's guide. Hope you can tell me where my mistake is. 🙂
(3,965 Views)
Accepted by topic author Klüs
Does this phenomenon occur if you sweep the frequency manually?
=== Engineer Ambiguously ===
(3,949 Views)
Have you tried setting the amplitude before configuring the sweep, not in the middle of it?
Ben64
(3,937 Views)
Thank you, that was the right hint. It was not a software problem but a hardware thing. I didn't consider that the measuring chain has such a frequency depending behaviour.
Obviously a beginner's mistake. Next time i will try to exclude these types of errors before i ask for help.
(3,923 Views)
