Suitable FPGA board
Which NI board is suitable to be used for image processing? The details that I want are:
  1. Language: Labview
  2. Applications : Image compression/processing (no need acquisition)
At this moment, I have NI MyRIO-1900. Is it suitable to be used for image processing?
Thank you
(3,000 Views)
See http://www.ni.com/white-paper/11417/en/
What is your frame rate, type of processing, and size of each frame?
ALE Consultants
(2,999 Views)
I used medical/DICOM images. Most of the images has maximum 550 KB of size.
I want to process the image using partitioning concept (N x N), where N= 4, 8, 24.
Type of processing is compression.
Thank You
(2,996 Views)
Did you look at the link posted above?
ALE Consultants
(2,983 Views)
Yes, I do. But, I don't want to acquire the image in real time.
Is it possible I use MyRIO + Vision Assistant for image compression?
Thank You
(2,978 Views)
Is there a reason you don't use your computer?  If you are just processing images that you already have stored isn't that what a graphics card is good for.
(2,950 Views)
Actually I want to process a medical image (dicom) not standard image (jpeg, png, etc) using FPGA board. My concern is to apply algorithms to the image pixel. I hope you understand what I try to said.
Thank You
(2,932 Views)
