Suggestion for Multipoint Limiter Function
Are the online NI Help files down?  I'm in LabVIEW.  I right click on a function and select Help.  NI comes back with a No Results message.
Message 11 of 14
(429 Views)
It appears that I have something that works.  The In Range and Coerce and Index Array functions were definitely the way to go for the back end of the design.  The front end was a simple for loop that stepped through each element in my velocity limit array, comparing each value with the velocity input.  Once the condition was met, the for loop iteration value became the index input to the Index Array function.
Message 12 of 14
(408 Views)
Hi stgislander,
Again this sounds like you should look up the Threshold1DArray function...
Message 13 of 14
(396 Views)
I will look at the Threshhold1DArray function again when I can get back to it.  As soon as I get something that works, I get pulled off onto another operation to code.  I sure there are better ways to do things.
Message 14 of 14
(380 Views)
