Suggestion Strips for String/Combo Box
Is it possible to display suggestion list when user types in String/Combo box which matches strings from a 1D array of strings, like in Google.
Example image of Google am showing below. I also wanted such a feature which help the user to select required input from the suggestions list
(1,653 Views)
My gut feeling says that, while it wouldn't be difficult, it would be tedious to set up.
Bill
CLD
(Mid-Level minion.)
(1,644 Views)
 Thank you for the reply. Ans am sorry to say that it doesn't meet my requirement. I hope string matching type (kind of) will be useful for me. Because if I am searching middle words also, it will be better to show the results as suggestion list.
Here one example am showing. I have implemented it with a String control & a Multicolumn list box. When user types in string control, matching words will be displayed in the MCLB & user can select signal from that MCLB.
But I want both the things incorporated in a single function.
(1,596 Views)
Elaborate
(1,595 Views)
Some options which can help you with that:
  1. An XControl, like the example linked to before.
  2. A .NET control which already does this (if one exists).
  3. Some tricks, like in this example, which launches a daemon to show the listbox.
If you want, my example here also has the bulk of the code for interacting with the listbox. You could probably merge all of these together into an XControl which would let you have a single control with a property node for setting the allowed strings.
___________________
Try to take over the world!
(1,537 Views)
