Subvi VI Properties - Dialog Open when required
I have a subvi with Settings for my main vi.  Using an event structure, I am detecting value change to spawn dialog for the user  be  able to change settings like path to file etc.
If not, I want defaults from that subvi to load automatically. If the user changes settings the first time, then I want those settings to be carried forward when the application is run even after two days. I dont want to right click on FP control and choose "Make current value default". I want what the user chose during run time to become the default until the user changes it again. Attached is the subvi that will open as a dialog when change settings icon is pressed on main vi.Thanks!
I may not be perfect, but I'm all I got!
(2,458 Views)
You can find one example here - https://decibel.ni.com/content/docs/DOC-15349
___________________
Try to take over the world!
(2,440 Views)
