Subroutine execution priority with Call By Reference nodes
Hi -
I have a VI which contains a Call By Reference node. I would like this VI to run with subroutine execution priority (the VI is small, is called frequently, and must run quickly). The VI being called by reference is itself set to run with subroutine execution priority. However, I get an error which reads: subroutine priority VI cannot contain an asynchronous node. What is asynchronous about a call-by-reference to another subroutine VI? Is there any way to get around this? Thanks.
Jason
Jason Rolfe
(2,695 Views)
This is what the help files mention:
Subroutine priority VI cannot contain an asynchronous node
This VI has subroutine priority selected in the Execution page of the VI Properties dialog box. It cannot use an asynchronous node on its block diagram. Asynchronous nodes, such as dialog boxes, are supposed to allow other VIs on the same thread to continue to execute while they wait to complete their own execution. However, subroutine priority VIs block the execution of other VIs on the same thread until the subroutine priority VIs finish execution.
You can correct this error in the following ways:
Change the execution priority of this VI. To change the priority, right-click the VI icon in the upper-right corner of the front panel or block diagram window, and select VI Properties from the shortcut menu to display the VI Properties dialog box. Select Execution from the top pull-down menu of the VI Properties dialog box, and change the priority in the Priority pull-down menu.
Remove the asynchronous node.
I am affraid that the call by reference node is asynchronous.
aartjan
(2,691 Views)
