Subpanel doesn't work in Runtime application
I created an application that uses a Subpanel. The Subpanel works correctly when I am running the code in LabVIEW, but nothing shows up when I use the runtime application. Are subpanels handled differently by the runtime engine than they are in the Full Development System?
(2,846 Views)
Hi Monroe,
Follow this link to a discussion that answers your question....
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=506500000008000000848E0000&ECategory=LabVIEW.LabVIEW+General
Hope it helps,
Nick
(2,846 Views)
It turns out that the problem was that I was using controls with type definitions. The type definitions weren't available to the runtime application and thus the VI that I was trying to run in a Subpanel couldn't be opened. One solution is to disconnect all of the type definitions. The other solution may be to place the type definitions in a folder at the same level as the SubVI so that the runtime application can find them.
(2,846 Views)
