Subpanel and executeable doesn´t work!
Hi there,
I have some trouble by generating an executeable of a VI wich includes a subpanel.
The result is the same with the NI Example "viewer.vi"! The VI runs perfectly, the sub-VIs can be loaded into the subpanel. But an generanted EXE file of "viewer.vi" doesn´t work!
What coulb be the reason for this?
I´m running LV7.1 on a W2k platform.
Thank you!
(2,724 Views)
You need to include the VIs plugin1.vi, plugin2.vi and plugin3.vi as dynamic VIs into the build script. They are located in the same llb where the viewer.vi is. These three VIs are loaded at runtime and the application build will not see them because they are ot part of the VI hierarchy of the viewer.vi.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,720 Views)
