SubVI with event structure does't work when called from main VI
I've following problem.
I have this VI: it works alone, but if I call it from a Main VI it doesn't works.
I already tried to use a reference, but it does't work.
It quiet strange also because if I open the VI in the Prject tree I can modify it.
If I open the VI direct clicking on it from the main VI it appears everytime in running.
I just have more masks who starts normally, but only this give me problem.
Thank you in advance for your hellp!
Do you have any suggestione?
Message 1 of 8
(3,493 Views)
I've the same problem.
Message 2 of 8
(3,503 Views)
Buona sera Ferdinando,
Do you really need to set that VI to reentrant?
I guess that's the source for this "appears running" problem…
How do you know?
In which way it does not work?
Any errors?
To create events for the event structure the frontpanel of your VI has to be open/available to the user!
A reference for what? What does not work?
What do you want to achieve by using any kind of reference?
On your VI:
- I would use much less "value" property nodes! No reason to place terminals in the first frame of a sequence… (Use more wire and shift registers!)
- Some Rube-Goldberg code inside: why do you need to output TRUE/FALSE in a case structure depending on the boolean case selector? (Event case "Quit")
- Bundle related controls in clusters. This will greatly reduce all that effort to enable/disable controls…
- It's a nice mix of German and English in this VI, often referred to as "Denglisch"… 😄
Edit:
Please keep discussions in one place! No need to post the same question twice!
Message 3 of 8
(3,495 Views)
Hi Ferdinando, what about the VI doesn't work? Can you be more specific?
I am using LV 2016, if you can do "file >> save for previous version..." i can take a look at it.
Message 4 of 8
(3,486 Views)
Eheheheh thank you for your suggestions.
I accept your corrections.
The aim was to clos ASAP this SW.
I mean it works very well if I start it alone in it's windows in debugging mode.
But if I call it from main VI and I pass some value for tables...
The event structure does'nt works.
I became a mask and that's all.
Message 5 of 8
(3,482 Views)
Hi Ferdinando,
How do you pass those values to the "tables"?
I repeat: the event structure will only react on user interaction! (Or "value signalling" property nodes.)
Maybe it's easier for you to write German? "Du wurdest zu einer Maske und das ist alles." ???
Message 6 of 8
(3,476 Views)
Accepted by topic author Ferdinando_Vino
This looks suspicious.
aputman
Message 7 of 8
(3,458 Views)
You are right, guy!
Thanks a lot for your support.
Sometimes, when we're tired and we write code for days... it's an hard work to make bug fixing.
You were very nice with me.
Thank you!
Message 8 of 8
(3,411 Views)
