SubVI not executable
Hello!
Anamnesis:
I installed my LabVIEW 6i (german) on a new computer. Because I got some errors concerning types and classes I installed the update to 6.0.2. During the mass compilation process I got several hundred times (really!) the message that lvdaq was not a 32 bit dll. I took the only choice which was "ok". After an hour the update was completed and the errors disappeared.
The problem:
Continuing to create a new application I realized that several predefined VI, such as "Read from Digital Line.vi" can not be executed. The advice to open the VI and is quite amazing, as I did never change these VIs which are included in LabVIEW. However following the advice over several levels leads to the insight that a function can not be found in a library. This reminds me to the messages when updating LabVIEW.
So I suppose both have the same origin. I it posible that my lvdaq.dll is broken and might this cause the mentioned effects?
And, if so, where can I get a healthy one?
Many thanks for your support!
Greetings,
Docbritzel
(3,127 Views)
Hi Docbritzel
Im not sure but maby this link [broken link removed; article no longer available] will help you.
regards
Manuel
(3,087 Views)
Hi Manuel,
nice idea. But I'm working with Win ME which does not have restrictions for user accounts.
Thank you anyway.
Docbritzel
(3,081 Views)
