SubVI doesn't work on program restart
I have a pretty complex main program that calls various SubVIs. All of them work except for the one I attached. Every time I close the main program or the SubVI it stops working in the main program until I open the SubVI, delete a connection and connect it again or delete and write a variable (the same value) and save. Then the main program works as it should.
I really don't know anymore what to do. Is it a bug?
Message 1 of 11
(3,012 Views)
@thomas.marcus wrote:
Every time I close the main program or the SubVI it stops working in the main program...
What do you mean by "stops working"?  Wrong values returned?  Program halts when calling the VI?  LabVIEW crashes when it is called?  You get a Blue Screen of Death?
Message 2 of 11
(2,998 Views)
right, forgot to say that. sorry.
it returns NaN.
Message 3 of 11
(2,976 Views)
Generally, around here, people don't try to debug pictures.  The reason for that is that it's impossible to debug a picture; and no one is going to try recreate a VI from a picture.
Message 4 of 11
(2,961 Views)
Accepted by topic author thomas.marcus
It look's like you don't have the Feedback Node wired correctly...
Try something like this...
=== Engineer Ambiguously ===
Message 5 of 11
(2,939 Views)
Please don't post BMP images.  They are way larger than they need to be.
The best image for LabVIEW code is PNG.  JPEG will do in a pinch.  But as others have said, actual VIs are best.
Message 6 of 11
(2,918 Views)
Using PNG instead reduces filesize dramatically:
Message 7 of 11
(2,898 Views)
nice, i will try it
Message 8 of 11
(2,889 Views)
Don't get stuck on image size.  Post your VI if possible.
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(2,877 Views)
Alright, I just thought since there are so many SubVIs I don't want to upload them all, and didn't know if it works without them.
Gonna try rewiring the feedback node correctly in a minute.
Message 10 of 11
(2,865 Views)
