SubVI Paths in installation File
I want to generate a VI Package (.vip) to give it to customers to install it with the VI Package Manager. The Package includes VIs (each VI has a SubVI called ErrorHandler) and a few Examples. My problem is, if I install the generated Package, the Examples and the VIs are expect the SubVIs in my working directory (the directory from where the package was built) and not in the installations directory (vi.lib or instr.lib). The searchingpath is more or less the correct one but after w few seconds, LabView needs my help and open the explorer to select the correct SubVI.
How can I change these Searchpaths reliable to start the examples and VIs after installation without searching?
Thanks for your help.
(1,204 Views)
Perhaps this is what You need.
Have a nice day!
(1,114 Views)
