SubVI 'EDX10A_Sample.vi':SubVI is not executable
Hello guys,
I installed a driver as EDX10A but I faced with this error.I also attached the VI project. In detail of error it says:"The subVI is not executable. You must fix all errors in the subVI before this VI can run."I couldn't understand what the problem is. Can you help me?
Message 1 of 14
(5,371 Views)
Hi quanthema,
The problem is a missing subVI named "EDX10A_Sample.vi" in your attachment…
Can you help me?
No, as long aas you don't provide the subVI (and the subVIs of that subVI)…
Message 2 of 14
(5,353 Views)
Hi GerdW,
I also attached the pdf of driver and I followed the steps in it. I am sorry but I didn't understand the name mismatch and what should I do to overcome it?
Message 3 of 14
(5,342 Views)
I also want to add driver folder too.but some files having .mnu extentions couldn't be sent.
Message 4 of 14
(5,338 Views)
Hi quanthema,
as soon as I point LabVIEW on the needed DLL the VIs can be opened without errors and are runnable!
You need to place the device driver in the correct place: be default the DLL is expected within instr.lib folder…
Message 5 of 14
(5,331 Views)
hi GerdW,
Since the very begining , I put the .llb and .dll file to instr. lib folder.(I attahced the display) And as I said before I followed the steps in pdf. In Pdf it also says that the same thing;
2. When installing LabVIEW under normal state, copy the [EDX10A] folder to the following location.
C:\Program Files(x86)\National Instruments\LabVIEW ****\instr.lib
(Note that **** indicates the version of the LabVIEW, installed in the PC.)
3. When installing LabVIEW under normal state, copy the EDX10A-errors.txt folder to the following location.
C:\Program Files(x86)\National Instruments\LabVIEW ****\user.lib\errors
4. Start LabVIEW.
Select [File] → [New VI].
Right-click the block diagram workspace to display the Functions palette.
Make sure the EDX-10A appears on the following menu.
[Instrument I/O] → [Instrument Drivers] → [EDX-10A]
Message 6 of 14
(5,327 Views)
Hi quanthema,
and WHICH errors do you get when following the manual?
You didn't explain this so far!
In which way aren't your VIs executable? Did you debug them?
Message 7 of 14
(5,322 Views)
Hi GerdW,
When I want to start EDX10A_Sample_VI and clicked to run button(broken) it lists lost of errors as sub-vi is not executable. I added display of error display.
Message 8 of 14
(5,317 Views)
Hi quanthema,
We already knew that.
What are the exact errors in the subVIs?
Message 9 of 14
(5,315 Views)
This is exactly why here I am. I couldn't achieve to see exact error. Therefore I couldn't solve it.
Message 10 of 14
(5,305 Views)
