Sub-vi
I did a Sub-VI but the problem is that there are some terminals which are loose, because I forgot to wire them with other nodes in the main block diagram of the program, so I want to figure out a solution to wire these terminals in the sub-vi to the terminals in the main block diagram.
The problem is very easy but I can't solve it!
(3,050 Views)
can you post the sub-vi?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,036 Views)
(3,034 Views)
You need to feed a wire into all of those Sine and Cosine VI's.  What number do you want to feed to them?
Is it one of the controls you already have on the screen?  Or another one in which case you need to make the control and wire it into them.  Then you would have to go to the front panel, right click on the VI icon and Show connector, then connect an empty terminal to the new control.  Basic LabVIEW skills. I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(3,027 Views)
