Sub.vi shrinking Main.vi
I have a main.vi which 'does' everything, and a sub.vi which displays
a simple multi-line string of status information (for some old-folks
here who need the security of a dumb ascii display). What I would
like to do is have the sub.vi panel be able to shrink the main.vi
panel to the toolbar. With the refnum approach, I can get the sub.vi
to CLOSE the main.vi, which shuts it down and is not thereby useful;
especially because main.vi is not restartable from the same refnum.
How do I (if at all) from a sub.vi cajole the main.vi to close/reopen
its window without shutting down its run state? GH
(3,141 Views)
Assume you have in sub.vi refnum of main.vi.
In refnum properties select Front Panel Window\Open. Set it to false - it will set main.vi Front Panel unvisible. Set it to true and it will be visible.
(3,141 Views)
nchernin wrote in message news:<5065000000050000004B790000-1021771306000@exchange.ni.com>...
> be visible.
Actually tried this before I posted here. The main.vi window closes
and the main.vi shuts down using this method. I need main.vi to stay
alive generating data...
(3,141 Views)
Look attached example.
(3,141 Views)
Hi all.
There is a LabVIEW library of Windows API calls. One of the commands is minimize. I think the .llb works well and is well documented. Goto www.ni.com and enter windows api function utilities 32 in the search bar.
Jeremy Braden
(3,141 Views)
