Stuck!
I'm trying to get a for loop to read a string word by word, I have tried several different things to no avail.
For instance:
Who is there-->(for loop) [converted string]--> Whot ist thert
This is killing me, thanks for the help!
Message 1 of 19
(5,689 Views)
Post your vi here
Message 2 of 19
(5,682 Views)
Post your vi here
Message 3 of 19
(5,682 Views)
Message 4 of 19
(5,675 Views)
Here's the sub vi I made.
Any suggestions on changing any of this would be great.
Thank you so much for helping me out.
Message 5 of 19
(5,660 Views)
I know it looks terrible, but I'm not very good at this stuff. Please help me:)
Message 6 of 19
(5,624 Views)
The simple solution (i cant open your .vi due to having 8.2) is send your string to the loop with a Shift Register. Inside loop, Match pattern to string, send Result after match to Shift register out, and Before match you let autobuild an array by connecting to loop border (should be an []). Then you'll have a string array with 1 word per row.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 19
(5,618 Views)
Hi
I can't open your attachment as I am using 8.5. Are you looking for some thing like this?
Sanad MM
Message 8 of 19
(5,612 Views)
Okay so what do I set as the regular expression?
Message 9 of 19
(5,611 Views)
Well, Sanad, I'm looking for something that will send words individually through a loop. I have a sub vi that puts it into pig latin so what I'm trying to do is get the words translated one at a time.
Message 10 of 19
(5,608 Views)
