Struct to C++ dll
Please help!
C++ code
typedef struct MyStruct
     char*  name1;
     char*  name2;
     char name3[10];
     char name4[10];
} mystruct;
int MyFunc(char* name1, char* name2, char* name3, char* name4)
How to call this to from labview CallLibraryfunction node
(2,850 Views)
Here is a KnowledgeBase article that describes how to call a DLL in C++ with a Call Library Function node in LabVIEW. I hope this helps!
Amanda Howard
Americas Services and Support Recruiting Manager
(2,822 Views)
You can use, Automation Refnum from the controls pallette. use it to select the dll you want to link and select the class( automation refnum) and the method (use invoke node) on the block diagram.
Hope it helps.
(2,820 Views)
