Strip path multiple times
Food for thought.
Wow, i like that. Stripping a path using Build Path? Who would of thought. Seems like this would of been a better feature for 'Strip Path'? Will have to remember that one.
"Everything should be made as simple as possible but no simpler"
Message 11 of 25
(2,803 Views)
@jvh75021 wrote:
I use the function Current VI's path and then pass the value to strip path. I know I need to go up three levels but putting multiple strip paths end to end yields the same path each time.
Maybe it is just a language thing, but I don't understand your statement "yields the same path each time".
"Same" as what? Are you saying that placing multiple "strip path" in sequence does not work right?
The suggestions to convert the path to string and back is not good, because it is OS specific and makes the VI non portable. The required string operations depend on the OS.
Also, Darin's method is windows specific and might not work on e.g. Mac or linux (I have not tried). You really should stick with the native path functions.
So, in order to strip a path N times, you would simply use a FOR loop as follows:
(If you feel you need that very often, wrap it into a subVI.)
Message 12 of 25
(2,793 Views)
In case you lose sleep over platform independence:
I avoid portability issues with paths two ways (the few times I care): (1) I have a subVI which simply returns the platform dependent separator (2) I have a second subVI which fixes paths so the separator is correct.  This actually has never been used by me for portability, it is used to catch the MUCH more common problem of user input with the wrong separator.  Easy to do when you bounce between Windoze and Linux.
I see a lot of near Rubes with people reconstructing relative paths instead of letting the build path primitive do its job.
Message 13 of 25
(2,777 Views)
Thanks. Your way is mo betta than mine, maybe. But matching the directory  name seems easier than calculating where to stop the array subset.But I am no array expert. Final path is longer on my development system due to SCM
This will strip the path based on the Directory name you insert. Is also case insensitive.
Rgs,
Lucither.
Message 14 of 25
(2,770 Views)
@Darin.K wrote:
Food for thought.
Darin,
This is most excellent. You initialize an array with "go up one level" syntax. Later you build a path. But what is that little hootus between the array init and the build path? I have looked at string, file and array functions and cannot find it.
thanx,
jvh
Message 15 of 25
(2,746 Views)
Thanks but it did not work for me. I fed something like C:\a\b\c\file.vi into the stripper function and fed the output into a 2nd  copy of the stripper fn. I put indicators on both outputs and both yielded C:\a\b\c.
Message 16 of 25
(2,743 Views)
Concatenate Strings
Message 17 of 25
(2,741 Views)
Can you attach a small VI that shows the problem?
Works fine here....
Message 18 of 25
(2,734 Views)
When trying to recreate the code shown above, did you remember to change the tunnels to shift registers?
Cory K
Message 19 of 25
(2,722 Views)
Even tough he quoted an entire post, I don't think he's talking about my code suggestion, but is refering to my quote:
"... Are you saying that placing multiple "strip path" in sequence does not work right?".
When putting two strip path end-to-end, no shift registers are involved. I suspect a crossed wire. 😉
Message 20 of 25
(2,716 Views)
