Strip Chart: Is it possible to rescale the x-axis depending on the number of data?
I would like to create a chart that will rescale its x-scale as the data comes in.  In other words, when there are only 2 data, the scale is from 0-2, and 0-3 for 3 data and so on.  Therefore, the chart will always be "full" and it will be possible to compare the overall data. (from beginning to end) by looking at the chart
(2,747 Views)
Accepted by topic author Akatsuki
You just need to set the x-axis to autoscale.
(You might need to clear the history buffer before each run using a property node).
(2,744 Views)
