Strings
Hello again,
Does anyone know how to make a backslash string constant in labview
Best wishes for the weekend
Svavar Von Eisland
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(4,785 Views)
Drop a string constant onto the diagram, right click inside it and select
'\' codes display. Type string.
Is that what you are after?
svabbi@my-deja.com wrote in message <7m4teb$a9o$1@nnrp1.deja.com>...
>Hello again,
>Svavar Von Eisland
(4,785 Views)
svabbi@my-deja.com wrote:
> Hello again,
> Svavar Von Eisland
I am not certain what you are asking, but I will give this a shot.
I believe what you need to do is put a backslash in front of the backslash.
It is called I believe "escaping" so the answer is use \\ to get a
backslash.
If you really wnat a backslash constant then drop a string constant on the
diagram
(from Functions -> Strings) , type in a backslash and hit enter.
Kevin
(4,783 Views)
