01-27-2015 03:25 PM
01-27-2015 03:59 PM
Done, I removed the Byte at port, and actually I´m testing the program (Y), thanks. 🙂
01-27-2015 04:03 PM
You can get rid of those case structures and the inner while loops. 50 is always greater than 0.
01-27-2015 04:04 PM
Shut down LabVIEW and try to talk to your device using HyperTerminal or TeraTerm or something like them.
Can you communicate with you device? What exactly do you have to type and what EXACTLY do you get back?
Does the reply come out as one continue line or does H and T print out as separate lines?
Are there any spaces between.
Or simply your communication loop.
Get rid of the Number of Bytes at Port
Write the T or H and read the reply
NOW tell us EXACTLY what you get back for the "T reply" and the "H reply".
Are there any ERROR and what are the Errors?
01-27-2015 04:50 PM
I'm giving tou you Dennis all the information that I actually I have, The real thing that I want to do Is to do a VI with multiple variables (like the example that I have upload before) using string and not the Visa Read or Write multiple times, Ok, i´m done with the Bytes at port that It was the suggestion of Crossrulz, I want to do this (picture above) maybe its a problem in my C program.
01-27-2015 04:52 PM
I´m already done Omar in that way, I´t works 😉 thank you
01-27-2015 04:52 PM
