String to number conversion
IS it possible to convert a string from   12:30:55     to a numeric . output of numeric should also display   12:30:55
Message 1 of 18
(4,594 Views)
Is it ok for you to use a timestamp instead of a numeric?
If yes, you can use the "scan from string" function like this :
Hope this helps
Epictetus
Antoine Chalons
Message 2 of 18
(4,589 Views)
NO
See the below code in that my time string will be incremented which i have to give to x axis of waveform . once see the code what i have attached you will come to know clearly
Message 3 of 18
(4,566 Views)
Oh, ok... the timestamp format can be cast to DBL with the "to DBL" primitive that you can find in the numeric palette.
Then to have your X scale to display time in the format (HH:MM:SS) you can right clic on the graph, select properties, go to the "Display Format" tab and edit the X-scale format as you wish, see example below :
Hope this helps
Epictetus
Antoine Chalons
Message 4 of 18
(4,561 Views)
no sir see this code now my input is string and output should be in dbl what to do
Message 5 of 18
(4,547 Views)
Is this ok?
Epictetus
Antoine Chalons
Message 6 of 18
(4,542 Views)
You can also thank TiTou for his work and his answers trying to help you instead of changing your needs with examples without any explanations!
Olivier L. | Certified LabVIEW Developer
Message 7 of 18
(4,538 Views)
output form of dbl should aslo appear as 55:06:33
it should not display  63393
Message 8 of 18
(4,530 Views)
HI Olivier,
How comes you're blue? Are you or have you been an NI employee?
Don't worry I'm used to customers who have evolving needs 😉
Epictetus
Antoine Chalons
Message 9 of 18
(4,524 Views)
And you should try to think about a solution by yourself!
It's not possible for a numeric Control to display Time Values, that's why Timestamp controls exist!
Message 10 of 18
(4,520 Views)
