String to decimal number cluster?
I'v sent a mouse position through the UDPsender and UDPreceiver, and on the  UDPreceiver-side, how can i get this coordinate- value in decimal number from the UDP-data String again? I'd tried to make this with "type cast", but it did'nt output the cluster value... how can i do this?
thanks!
Message 1 of 24
(4,574 Views)
A sub vi is missing...
Try STRING >> STRING NUMBER CONVERTION >> STRING DECIMAL TO NUMBER
Message 2 of 24
(4,567 Views)
Hi xin,
in which format is the mouse position in the string? Do you create it with LabView?
Mike
Message 3 of 24
(4,558 Views)
Oh ya, sorry, I'v forgot to post the error handling vi, so here you are....
by the way, thank you two guys for the replys:)
(first run the UDPreveiver.vi, then run the UDPsender.exe, input 80, or 100...) and you can see, what i'd mean in Labview.
Message 4 of 24
(4,551 Views)
Hi xin,
try the "Spreadsheet String to Array.vi".
Mike
Message 5 of 24
(4,549 Views)
no, it doesn't work, there's nothing in the Aarry...
have you another idea?
Message 6 of 24
(4,545 Views)
Hi xin,
i´m sure it works. But if you insert data with labview and press return for a line break, there is only a "\n", but your program returns "\r\n". check the attachment.
Mike
Message 7 of 24
(4,540 Views)
yes,yes, this time, it works!
Tahnk you very much, mike.
ahh, but i want just a "cluster", the UDPsender(.exe) sends every time two values(x,y),  and later i will process another thing whith this coordinate, but not with a array.
how can i get only two values from this array everytime?
Message Edited by xin.li@tuhh.de on 02-20-2008 07:59 AM
Message 8 of 24
(4,536 Views)
Hi xin,
you can use the "Index Array.vi" and bundle it then to a cluster.
Mike
Message 9 of 24
(4,531 Views)
like this?
I don't know,how do it right
Message 10 of 24
(4,523 Views)
