String to array for anaylsis
Dear All,
I got some problems from my labview problem.
Firstly, there is a part of my program(attachment). It is designed to save sring data to a .txt or .xls file.
When it ran, it worked.
If i set the type of save file be .txt, it displayed that (attachment)
If I set the type of save file be .xls(Excel file), it displayed all the data only in the column A.(Attachment)
I could not use it for doing analysis.
Who can help me to solve this problem?
Secondly, If all the data are strings, how can convert them into array? I have tried many times but i still could not do that. who can give me some hints or examples?
Thank you.
KIM
(3,149 Views)
If you want to have Excel automatically open the file and place the data in columns, you should use a tab separator instead of 4 spaces.
Not sure where you want to get a string array. On the entire string, you can use the function Spreadsheet String to Array. This requires you to specify the correct terminator.
(3,135 Views)
i can do it now!
Thank you very much!
(3,109 Views)
