String to Number Conversion
I am getting a string measurement "-2.927184E-04" from the multimeter. I want to convert to the number.
I am using "Fract/Exp String To Number," but I could not get a number
Please suggest me any solution
(1,113 Views)
Accepted by topic author Rshah31
Hi Rahah,
remove the quotation marks...
Which DMM do you use that sends data within quotation marks?
(1,108 Views)
Hi
Thank you, I have also tried this out.  and I am getting output  -2.
I have also increased number formate.
output could be  -0.000294 something
I could not got this
(1,098 Views)
@Rshah31 wrote:
Hi
(1,071 Views)
I personally prefer the scan from string vi to have more control on the format.
the format string allow to define the decimal point ( %.; )
Just in case you run into the problem, that a device is using the comma and your local setting is point.  Assuming that the string(or device) always use the same decimal point ...
edit: and it would work with the quotation marks 😉
or generally speaking with nearly all type of strings and data to exstract
Greetings from Germany
Henrik
LV since v3.1
(1,044 Views)
