String to Array
Hi all. Need a little help with a project.
So I am reading in a string of 8-bit bytes, for example "10101010 11111111 01010101" etc. I need to extract each byte and then display it as a decimal. I tried using String to Byte Array and a few others but coudnt figure it out. Any help would be most grateful!
Message 1 of 11
(6,363 Views)
All bytes are 8 bit, but you need to clarify how they are represented in the string. Is your example a binary formatted string consisting exclusively of the two characters 0 1nd 1? It also looks like ther is a delimiter after each group of eight characters. What is the delimiter (space, tab, etc.)?
If you want help, please attach a small VI that contains a typical string as default data so we get a better idea what this is all about. So far the problem is quite ambiguous.
Message 2 of 11
(6,353 Views)
There are actually 2 options Im looking at.
The first is just like i wrote. Binary formatted string of 8-bit bytes seperated by a space.
The other option. the more preferrable one which i haven't had much luck figuring out it is reading in 48 8-bit bytes continously one after the other. and then sorting and displaying each of them
Message 3 of 11
(6,327 Views)
Use "Spreadsheet string to array" with space as delimiter, an integer U8 1D array type, and a binray format specification.
This sentence makes little sense? A "fixed size" (48) and "continuously" are contradictory. Sorting by what (e.g. alphabetical by binbary formatted text? Numerically by scanned value?) Displaying each or displaying all? Display how?
Message 4 of 11
(6,316 Views)
Sorry, "continously" was a poor choice of words. Basically, i am reading data from a serial port. There are 48 bytes (8-bits in binary format) being "dumped" into a serial port and I have to read them. I am using the VISA read function in Labview to read them all, but this function reads the data as a string not an array. so i have been having trouble trying to figure out how to display each byte seperately.
Apologies if this is too confusing.
Message 5 of 11
(6,308 Views)
I had the same problem, and here's how I solved it:
  • Write a VI called Get One Byte.  Inputs are VISA In (the line associated with your VISA device) and Error In.  Do a one-byte VISA Read, use String to Byte Array to convert to an Array of Bytes, then use Index Array and return the (only) first byte as a U8.
  • Put this Get One Byte function inside a For or While loop with an autoindexing Byte Out tunnel and use it to create the array of Bytes you need.  [I wasn't clear if your array is 48 bytes or 48 bits = 6 bytes).
  • In my case, I was getting 12 bytes that represented 6 I16 quantities, so I passed my array of 12 Bytes into another function that combined the bytes pair-wise into an I16 array, and then did some arithmetic to change the numbers into properly-scaled quantites.
Message 6 of 11
(6,268 Views)
Thanks, any chance you could attach a picture or the VI itself?
Message 7 of 11
(6,256 Views)
Or could you perhaps explain in a little more detail how to use autoindexing Byte Out tunnel and use it to create the array of Bytes you need, and also how you passed the array of bytes into another function that combined the bytes and displayed them. Thanks
Message 8 of 11
(6,201 Views)
Sounds like LabVIEW tutorials are needed.   http://www.ni.com/getting-started/labview-basics/
Message 9 of 11
(6,188 Views)
Tried that before i posted in the forum.
Message 10 of 11
(6,175 Views)
