String format
See the attached file.
Regards
Freelance_LV
TestAutomation Consultant
Message 21 of 26
(1,302 Views)
Hi
sorry i use version 2009. Could you save as this version please?
Message 22 of 26
(1,297 Views)
Try this. I hope it will be accessible
Regards
Freelance_LV
Message 23 of 26
(1,292 Views)
Yes,
its accessable.
Thanks for your hard work. I'll give it a go and let you know how it goes...
Thanks again.
Message 24 of 26
(1,286 Views)
i've tested this section and it still is not quite right.
It doesn't add any data to the end of my data file.
It only over writes all of my data with the new data set.
It needs to remove the old data and add the new, keeping any old serial numbers in there.
I'll have a play with it.
Message 25 of 26
(1,280 Views)
I am not sure then, what it is not working.
For me, it seems to be working fine. I hope you have removed the code parts labelled 5 and 6. Anyways, try that module.
Regards
Freelance_LV
Message 26 of 26
(1,273 Views)
