String for Reading PV from Eurotherm 2404
Here is the attachment containing the LabView files.
Ipshita C.
Message 21 of 49
(3,428 Views)
Dear Ipshita C.,
I'm not in my office today, I'II see your labview file tomorrow. Thanks a lot for your help.
Have a good day
Cath
Message 22 of 49
(3,413 Views)
Just a remark,
I use Labview 7.1
Cath
Message 23 of 49
(3,411 Views)
*This post is about direct connnection to the Eurotherms over ethernet, it has nothing to do with the OPC Server discussion*
Hello (Bon Jour?) Cath,
to answer your questions:
1.) I use the MB Ethernet Master Query.vi
2.) The regular iTools. See screenshot.
 You will have to configure the Eurotherms with EndSetup.exe. There you will also need the IP Adress of the Eurotherms. The IP-Address has to be configured directly on your Eurotherm controller.  It is in the IO-Section. Consult your Eurotherm Manual for this.
3.) You will need to supply the IP-Address and close the connection afterwards. The following screenshot shows how this can be done:
Greetings,
Thorsten
Message Edited by krasserTerror on 06-24-2008 03:56 AM
Message 24 of 49
(3,404 Views)
Dear Ipshita,
unfortunatelly, the vi you give me are for serial connection between Eurotherm controller and my PC. I don't know if it is possible to transform the TCP/IP in a serial signal ? I think it is not possible.
Thanks you anyway
Cath
Message 25 of 49
(3,382 Views)
Hello Thorsten or Bonjour,
Thanks a lot for yours answers. I progress but all is not OK.
I use the free iTools (find in the eurotherm site), do you thinks it is the problem. When I run a scrutation, iTools found any device but when I ping my IP adress, the green led run in the ethernet cable, the communication is OK. In Labview, with your Vi, the TCP connection is OK. I'm not still desesperate but....
Friendly
Cath
Message 26 of 49
(3,380 Views)
great !
The clone of your scheme is OK for me. I can read a register ! Now I must understand how give a command to my 3508.
Thanks you very much et perhaps see you later...
Cath
Message 27 of 49
(3,400 Views)
You can give commands by writing registers:
Message 28 of 49
(3,385 Views)
Yes, Your scheme is perfect, now I can give a Tset command for the 1st loop of my controller. Perhaps do you know how to give a second Tset for the second loop ? I'II search. Perhaps, I can use the Channel H and The Channel J of the controller. I don't know.
Cath
Message 29 of 49
(3,383 Views)
Sorry, I only have one loop in my controllers. But if you have iTools running you should be able to browse to the parameter and see the address.
Message 30 of 49
(3,380 Views)
