String data to Sign data
I am using a device where I receive a string data output which has a meaning.
For example:
:000000 -0067U 0004 -0578
:000000 -0066U 0004 -0579
:000000 -0066U 0003 -0579
:000000 -0066U 0003 -0580
 I need to extract the 9th and 11th character through a string subset.
I have a question, please the attached VI:
1. Is it correct extraction method? any other suggestion?
2. The 9th character actually is the sign of character 11 i.e +(if space) and - (is shown as minus)
Then I have to take this number for e.g -5  or +5 then use in another calculation but problem is how can I convert the _ and +  from string to the number? then how can I make the 9th and 11th character as one number.
Message 1 of 12
(4,934 Views)
For the second question, for there is a space if + but - for negative.
I tried some conversion method.
Please see the attached.
Message 2 of 12
(4,928 Views)
Hi Kraze,
given your description of the problem and the provided data I would try this:
"Then I have to take this number for e.g -5  or +5"
In your example data 'this number' is always zero...
"how can I make the 9th and 11th character as one number."
- Use comparison functions like "equal to -" and simple math?
- Explain what you really want and give examples that fit...
Message 3 of 12
(4,926 Views)
I'm not clear on the requirements, but I'm thinking this:
Can you tell us what the output should be for this input?
Jim
Message 4 of 12
(4,916 Views)
Hello Jim and Greg,
Thanks for your replies!
Please see the attached VI I have seperated out the VI as per suggestion given by you two.
GregW as per your suggestion how can I get the number as -7 or -8 coz we ae extracting the numbers seperately.
Jim I didnt get the output, received as per the pic you posted. Please see the VI and suggest.
Message 5 of 12
(4,899 Views)
Hi Kraze,
is it so hard to set up some simple math to combine sign and number?
Btw. you wrote my name two times in your VI - both times spelled wrong. Is the name too long or to hard to spell?
Message 6 of 12
(4,885 Views)
Maybe the last part can be simplified. Please see the image.
I modified your input a little bit since your data only contained "minus". I changed row 2 to have a "space" which should be interpreted as positive sign. Moreover, row 4 shows a explicit "plus" sign in the ninth position. Note that both space and plus are correctly interpreted as positive.
Consider sanitizing the input. The 0th-row with "-0587" does not follow the syntax of all the other rows so it should be removed.
Message 7 of 12
(4,871 Views)
You still didn't explain what the output should be for this input.
Jim
Message 8 of 12
(4,865 Views)
Sorry! GredW that I misspelled your name.Smiley Surprised
Thank you all for your suggestions!
Special thanks to Jim and GredW for your help.
Message 9 of 12
(4,832 Views)
Hi Kraze,
"Sorry! GredW that I misspelled your name."
Again misspelled two times...
Message 10 of 12
(4,816 Views)
