String array to multi line string conversion?
Is there a way to convert a 1 dim string array to a multi line string?
I am retreiving data from a txt file one line at a time and buliding a string array.  I want to convert this array into a multi line string so that it can be inserted into a report and printed.
Would it be easier to create a table and insert it into the report as a table?
Thanks in advance,
doloop
(4,383 Views)
You just have to use the Array to Spreadsheet String function on the String palette. For the delimiter, I used the Carriage Return constant ubt you can just as easily use the End of Line or Line Feed.
(4,379 Views)
