String Max Size on Stored Procedure Calling SQL Server
Hello, I'm working on a Stored Procedure called from Labview but I have a problem when I set a String Parameter greater than 11440 characters.
I tried by executing this SP from SQL Server Query Window and it runs ok even when I input a bigger string. but when I do it from Labview I get the following Error:
I attach the VI that call's Stored Procedure.
Hope you can help me.
(2,944 Views)
That error is coming from ADO and not LabVIEW. The SQL Server query does not use ADO I believe. You may have better luck checking with Microsoft to see what limitations there are with ADO.
(2,923 Views)
Hello lenin_7,
As Dennis says, this error comes from the ODBC driver and not from LabVIEW, I found some Microsoft links that might help you with this issue:
http://www.lawebdelprogramador.com/foros/Visual_Basic_Avanzado/853535-Datos_tipo_string_-_Error_en_t...
http://code.activestate.com/lists/perl-win32-users/17716/
Hope this information works for you!
Luis CT
(2,873 Views)
