String Indicator Hex Display Limit Bytes Per Line
Hey,
I was wondering if there is a way to limit the amount of bytes per line in a string indicator that is in the Hex Display mode.  I am reading in 50 bytes using the VISA functions and I would like look at sets of 50 bytes each on a new line.  I tried just resizing the indicator but I found that if the 50 bytes have a lot of large characters like C's and D's then it will overflow to the next line and become a mess to look at.
(3,164 Views)
Accepted by topic author Gus67
@Gus67 wrote:
Hey,
I would suggest using a fixed-width font, such as Courier New. This way, for 50 characters, it will always be the same length on the indicator.
(3,150 Views)
Haha great idea.
(3,131 Views)
You could append a linefeed character after each read if you know that you're always going to read 50 bytes.  But, then, you'll still have the strings misaligned if you don't use a fixed-width font and you won't be able to easily compare different readings in the indicator.
Jim
(3,129 Views)
