Streamlining an Installer
Hi, I've got an application that I've built an installer for.  It uses 1 PCI-6143, 4 serial ports, logs data to disk, and displays a chart with 16 plots on screen.
When I build the executable, it's only 1.05 MB.
When I build the installer, it's a whopping 766 MB!!!  Under additional installers, I've got NI LVRTE 8.5.1, M&A 4.4.1, DAQmx 8.7, VISA Conf Supp 4.3, and Visa Runtime 4.3.  I don't think I can get away without these (trial and error), but certainly don't need every MAX driver - just the 6143 - but don't see how / where to remove unneeded drivers.
I'd like to get this down below 640 MB if possible, and imagine much smaller is possible.
David Friesen, B.Eng, CLAD.
(2,363 Views)
When you select the DAQmx driver in the Additonal Installers section, you have the option for different run-times. There is no such thing as separate drivers for each DAQ device but you can choose a minimal install without any documentation, ADE support for languages, etc.
(2,355 Views)
