Strange situation. A Vi makes LV crash
I was working in a Vi and when I ran it, LV crashed. After a few crashes I started deleting things until I left just the controls and indicators and it still crashed. Any idea what can it be? Any tool to check that, a kind of "repair".
Marce
(2,953 Views)
could you post the vi in its original form? Does it have a call library function in it?
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,945 Views)
Every once in awhile, VIs get corrupted (usually due to a disk I/O error). In LabVIEW-speak, you probably have an insanity, something that “cannot be”, but is. Many times, you can cure the problem by creating a blank VI, selecting everything in the insane VI, copying it, then pasting to the blank VI. This process causes LabVIEW to do a sanity check of everything and will sometimes fix it. If this doesn't work, you will probably need to rewrite the VI.
(2,915 Views)
I recently experience a similar situation. What I will suggest is you use a process of elimination to identify what is causing the corruption. I'm sure you will find out something interesting.
(2,902 Views)
Although I've already rewritten the Vi from a backup, here's the Vi that crashed but it has just controls and indicators. And it still crashes.
Marcelo
(2,866 Views)
