Strange in Intensity Graph
Hi all,
I'm trying to review our image data grabed by CCD camera.
The image data is a 2D array and each value stands for the gray value
read on the pixel.
I use both mathematica and LabVIEW to see the same image data, but the
results are different. LabVIEW seems to give a result with rotated
graph(90 degree). Does anyone know what happened to my program?
F.Y.Chang
(3,076 Views)
Are you using Labview to read in the 2D array from a spreadsheet program or is it connected directly to the camera? If you are reading it from a spreadsheet you might try transposing the array.
(3,076 Views)
Feng-Yin Chang wrote:
> Hi all,
> read on the pixel.
The Intensity-Graph is a Graph. The coordinate-system of this starts in
the lower, left corner with 0,0, while Images normaly start with 0,0 in
the upper, left corner. This normally flipps your image vertically.
2-D Array can be transposed, so that the axes are changed. You can solve
this by just right-clicking on the graph on the frontpanel and select
"tra
nspose array" in the context-menu.
I hope this helps
Marco
(3,076 Views)
The 2D array was read from a spreadsheet.
But I want to know why the result shows the transposing one. 🙂
Feng-Yin Chang,
Institute of Physics,NCTU,Taiwan
(3,076 Views)
