Strange Problem with app builder and daqmx
I created an exe. This is working  on  development system. Then i created installer include daqmx an runtime engine. Now it find only virtual channels.
In daqmx on target system i deleted all tasks and scales. Then i imported the config file from  development system and it has the same effect. Where can i find out the Problem?
(2,673 Views)
in your problem description, you said that you could only find virtual channels.
There is a possibility that you have not installed any driver support (NI-DAQmx, for example).
Here is a link where you can find out, if you have the correct packages on your MAX.
If that was the case, I would recommend a repair of the MAX software (Add Remove Programs » National Instruments Software).
Greetings and Regards,
James
James
(2,586 Views)
