Strange IDN? returned string
I don't know how they designed the firmware but different interface (USB vs ethernet) can behave differently.  I've seen firmware designs that give you entirely different menu structure and access levels depending how you talk to it.
Message 11 of 17
(1,185 Views)
@tian66 wrote:
I can control the load through USB. Do you think the cal mode will lock ethernet communication, but not USB?
Thanks!
I can't say one way or another without the users manual.  (Silly Chroma) but its easilly possible-  If the instrument suddenly changed behavior after a Cal lab tech got to it I would very much suspect the cal lab tech did something.  Again, can't tell without a manual....
"Should be" isn't "Is" -Jay
Message 12 of 17
(1,176 Views)
@JÞB wrote:
Thanks!
I've even seen instances where a manufacturer will "do you a favor" by updating the firmware without telling you when you send it out for a cal.  Then you wonder why your app isn't working any more.
Bill
CLD
(Mid-Level minion.)
Message 13 of 17
(1,170 Views)
I see. Thanks
Message 14 of 17
(1,142 Views)
bad post
Bill
CLD
(Mid-Level minion.)
Message 15 of 17
(1,129 Views)
Chroma support cannot figure out this problem. What they can do is asking me ship back the ethernet card and check that.
So I think I have to move on by using USB instead of spending time todebug with them.
Message 16 of 17
(1,121 Views)
We also have all kinds of hell getting these loads to talk correctly.
They are extermely picky.
If you figure this problem out, please post.  We find that we can alternately get one or two loads in the bay to talk, and then it latches us out and we can't get it to respond any further.
Message 17 of 17
(1,080 Views)
