Strange DAQmx Timing Source Timed Loop Error
I have a digital edge counter fed into a timed loop. Everything works fine until I stop the loop, and stop the DAQ task. Once I restart the loop it fails with "resource is reserved". Attached is my code.
Message 1 of 10
(4,457 Views)
I've done some experimenting, it seems that if the VI is stopped, some kind of internal resource is released. I could not find a VI that releases any such resource related to timers or timing sources. Does anyone have any information on this?
Message 2 of 10
(4,453 Views)
Hi there
Please post some code so we can have a deeper look.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 3 of 10
(4,434 Views)
Here is a piece of code to illustrate the issue. If the timing source is created in the loop (it will be created each loop iteration) the error occurs. If it is moved outside the loop, and only created once the issue is resolved. Is there a way to RELEASE the timing source so that it can be created again? If the VI is stopped, this "resource" is released. I want to programatically release it.
Note the error comes from the timed loop Error terminal that is Probed (50).
Message Edited by bkb on 10-08-2008 09:52 AM
Message Edited by bkb on 10-08-2008 09:53 AM
Message 4 of 10
(4,430 Views)
No, this is only a picture of a piece of code. Please post some code, this will help us to solve your problem.
Best regards
chris
Message 5 of 10
(4,424 Views)
There is nothing else required to post that illustrates the problem. Everything that contains a properly illustrated problem is in the previous post.
Message 6 of 10
(4,418 Views)
The whole point of this is that I need to change the Edge count on my timing source while the program is running. I fail to see how you cannot determine the problem based on my code snippit ts.jpg.
Message 7 of 10
(4,409 Views)
Here is a VI (click the stop button to generate the error)
Message 8 of 10
(4,394 Views)
Accepted by topic author bkb
I believe the problem is that when you configure a Timed Loop to use a DAQmx Task as its timing source, the Timed Loop is automatically set up to start the task when the loop starts. Here, you don't seem to ever stop the Counter task before restarting the Timed Loop. So the second time you run the Timed Loop, it tries to start the Counter task again, and sees that a task is already running with that resource (from the first Timed Loop run).
If you use the Stop Task function for the Counter task after stopping the timed loop, you should be able to restart things.
Jarrod S.
Message 9 of 10
(4,376 Views)
Thanks, can't believe I didn't try that.
Message 10 of 10
(4,369 Views)
