em 07-27-2021 06:39 AM
Hello GerdW,
In this case I can use simulated DAQ select strain and add waveform graph record.
But looking like that is very simple will only require two blocks to complete point 3 if I understood right.
Best Regards
07-27-2021 06:44 AM - editado 07-27-2021 06:46 AM
Hi Gustavo,
When you stick with ExpressVIs then you need just two functions.
When you want to impress your teacher you should go with DAQmx functions - as explained in all those example VIs coming with LabVIEW!
Btw. as your task description talks about "measuring voltage signal" you should NOT select "strain" in the DAQAssistent! (Again: re-read your homework description very carefully!)
em 07-27-2021 06:55 AM
Dear GerdW,
Understood, I am just running out of ideas.
I can simulate the voltage from the simulated DAQ but how this can be compared to the output voltage of a Wheatstone bridge ?
Best Regards,
em 07-27-2021 07:08 AM
Hi Gustavo,
You cannot compare the simulated voltage signal of a simulated DAQ device with a real signal of a real bridge-type sensor!
(That comparison is not part of your homework description. Re-read the description carefully!)
em 07-27-2021 07:18 AM
Hello GerdW,
Point 2 What should I consider adding to my circuit before connecting it to a Daq device ? Which device ?
Point 3 design and implement a VI to acquire the output voltage using a simulated Daq device.
I assume the output voltage will be simulated by the simulated DAQ device right ? therefore I just need to add waveform block ?
Best Regards,
em 07-27-2021 08:22 AM
Hi Gustavo,
I guess your teacher taught you about basic bridge measurements, or you got a book on electrical measurements to read on!
Point 2:
Did you try to select a DAQ device on your own? Which ones would you prefer? Why would you prefer them?
What have you learned about measurements using bridge-type sensors? What does your books tell you about it?
Point 3:
I did point you on those example VIs coming with LabVIEW/DAQmx? Did you open them already? Which one of them did you look at?
What is a "waveform block"? Until now you refused to attach any VI of yours at all - and you are not even able to read the exact function names in the context help window…
What have you tried so far?
em 07-27-2021 08:45 AM
Dear GerdW
I don't have any DAQ device.
Best Regards,
Gustavo
em 07-27-2021 08:51 AM
Hello GerdWW,
Getting back to your question.
A perfect balance Wheatstone bridge the voltage output should be 0 where one of arms resistor would be replace by a strain gauge in this case the bridge is not balance anymore therefore when stress is applied the rate will change where can be measured from the voltage output.
Best Regards,
Gustavo
em 07-27-2021 09:00 AM
Hi Gustavo,
But it's your job (aka homework task) to select a DAQ device!
Did your teacher present you a possible range/selection of DAQ devices to choose from?
em 07-27-2021 10:06 AM
Dear GerdW,
No,
I am not sure what DAQ device to select.
All the best.
