Strain Gauge Signal
I have two strain gauges, and I want to get both signals. How to connect so that I can get them. For now, the two wave charts have the same output, even the strain is different.
(2,189 Views)
What is that express VI you are using to get the signal?  I have never seen that one before.
It looks like it is set up to only output a single value considering the output terminal says "C/AI0 (AI0)"  How do configure that express VI for multiple channels?
There is no way to get a 2nd value out of it right now since it is only outputting a scalar value.
If you attached your actual VI, then we can poke around in it, figure out what that express VI actually is, and open up its configuration panel!
(2,184 Views)
I use the MyRIO, and I am not sure how to use it to get two signals
(2,177 Views)
